OK I give up, how do you install harley OEM exhaust gaskets ?? I am going nuts and don't want to damage them but I am thinking about pulling the hammer. There is got to be a tick ??
some oil on the outside of them and around the receiving end worked for me- my fingers have gotten them in the past 2 times, i suppose a rubber mallet with a very gentle tap should be safe but i never did that.
I used wd-40. You do have to be carefull not to get canted when pushing them in. If you could find something about the same diameter, (large socket)that would help push them in.
Same as bhaxton. I use to almost ruin my gaskets trying to get them in to the head. A buddy told me to put them in a freezer for several hours and they will slip in much easier. So I usually freeze mine over night in a steal bowl and the next day I no longer have a problem fitting them in.
