Throttle Problem???
Throttle Problem???
I'm seriously starting to regret the decision to get rid of the old Dyna's and buy this 08 Ultra. So here we go....
We were on a trip Thursday and bike was running fine. We pull up to a stop light. When we take off the check engine light comes on and the bike goes dead. Luckily we were able to drift over to the side of the road and turned the bike off and back on and it restarted. We get off on the exit and it happens again. The bike check engine light comes on and the bike goes into limp mode with no throttle response. It happens 3 times and then no problems the rest of the trip there. We thought maybe it was overheating for some reason. It ran fine the rest of Thursday and all day Friday.
Saturday we are out and it happens again. But this time we had more trouble getting it to start. Again, check engine light, goes to idle and no throttle. Finally after about 10 minutes it fires back up and run fine the rest of the day.
Sunday we start heading home and after about 10 miles it happens again. We were able to get her going but only for about 20 more miles. Then we were on the side of the road and Sean is now tearing into the bike trying to find a problem. He tried disconnecting the PC auto tune. He tried disconnecting the PC. No luck. He checked connection, checked fuel lines, etc. Then it fires up and sounds great. Put the seat back on and saddle bag and cancel the tow truck and get ready to take off...guess what?! Yep, we didn't get anywhere. Called the tow truck back and had the bike towed to the nearest HD Dealership. They were getting ready to close and wouldn't be open until Tuesday. They pulled the codes and it threw 8 codes all related to the throttle by wire in some manner. We figure since he was messing with it the bike stored a bunch of codes. We didn't want to leave the bike 2 hours from home for 2 days so a friend came and got us and loaded her on a trailer and got us home. Funny thing is after the bike sat for an hour it fired right up and Sean was able to ride around the parking lot and pull her on the trailer just fine. Then when we got home it fired up and he rode it into the garage. Next day....DEAD. Won't even start now.
Looking around here and some other boards it seems to be an ongoing issue with these throttles. But it seems it can be anything from cleaning the contacts to replacing the ECM or wiring harness. Any suggestions on how to narrow it down as we no longer have an warranty. Anyone had this happen to them?
Sean did clean the contacts and grease them but it didn't do anything.
first step is to remove and reset the connector to the throttle body. ( at 7 o'clock as you look at the TB from the right side of the bike)
next is to cycle the ing on/off waiting for the fuel pump to stop 4 or 5 times- with the switch in run position and not touching the throttle at all ( and learning to use the ign. switch rather than the kill switch to turn off the motor- with the right hand , so that the throttle is at "zero" when the ecm looses power and powers up again.
on a bike with a piggyback tuner, removing and/or reseting the tuner connection can be the fix.
if bars have been changed ( so someone rewiring the throttle) that can be a problem
some aftermarket grips ( kury) have been reported to have the internal mating gear break loose, causing no or intermittant throttle control
those would be my first guesses
mike
mike
I know he's cycled the on/off to reset the ECM. He does have the Power Commander & Auto Tune installed. He's tried disconnecting them.
Sean picked up a few of the cheaper fixes today to try them first. Let's hope one of them work. I've read it is usually either the connector behind the air cleaner or the connector to the ECM that's the issue.
The pins going to your air cleaner are probably fretted and need to be replaced, I have had this happen on my 09 this year and HD is aware of the pin fretting problem.
Harley Diagnostic Codes
To access codes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" (on mine the “t” looks more like a “╘” )with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
1 - Record the codes.
2 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 3 If the code is current it will reappear.
4 – Press and release the odometer reset button to continue to the next module.
5 – Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
1. P0605 ECM FLASH Memory Error
2. P0603 ECM EEPROM Memory Error
3. U1300 ECM Serial Data Low
4. U1301 ECM Serial Data High
5. U1097 Loss of Speedometer Serial Data to ECM
6. U1064 Loss of TSM/FSFM Serial Data to ECM
7. P1003 System relay contacts open
8. P1002 System Relay Coil High/Shorted
9. P1001 System Relay Coil Open/Low
10. P1004 System Relay Contacts Closed
11. P1009 Incorrect Password
12. P1010 Missing Password
13. P06415 V+Vref 1 Out Of Range
14. P06515 V+Vref 2 Out Of Range
15. P0373 CKP Sensor Intermittent
16. P0107 Map Sensor Open/Low
17. P0108 Map Sensor High
18. P0374 CKP Sensor Synch Error
19. P1600 EFI Module Processor Internal Error
20. P1270 TGS Validation Error
21. P2107 EFI Module Processor Internal Fault
22. P2122 TGS1 Low/Open
23. P2123 TGS1 High
24. P2127 TGS2 Low/Open
25. P2128 TGS2 High
26. P2138 TGS Correlation Error (Twist grip sensor)
27. P0120 TPS1 Range Error
28. P0220 TPS2 Range Error
29. P0122 TPS1 Low
30. P0123 TPS2 High/Open
31. P0222 TPS2 Low
32. P0223 TPS2 High/Open
33. P2135 TPS Correlation Error
34. P2119 EFI Motor Throttle Body Range Performance
35. P2100 EFI Motor Circuit Open
36. P2101 EFI Motor Circuit Range Performance (Actuation Error)
37. P2102 EFI Motor Circuit Low
38. P2103 EFI Motor Circuit High
39. P2176 EFI Closed Position Not Learned
40. P1514 Air Flow Fault
41. P2105 EFI Forced engine shutdown
42. P1501 Jiffy Stand Sensor Low
43. P1502 Jiffy Stand Sensor High
44. P0572 Brake Switch Low
45. P0117 ET Sensor Low
46. P0118 ET Sensor High
47. P0112I AT Voltage Low
48. P0113I AT Voltage Open/High
49. P1351 Front Ignition Coil Driver Open/Low
50. P1354 Rear Ignition Coil Driver Open/Low
51. P1352 Front Ignition Coil Driver High/Shorted
52. P1355 Rear Ignition Coil Driver High/Shorted
53. P1357 Front Cylinder Combustion Intermittent
54. P1358 Rear Cylinder Combustion Intermittent
55. P0261 Front Injector Open/Low
56. P0263 Rear Injector Open/Low
57. P0262 Front Injector High
58. P0264 Rear Injector High
59. P0562 Battery Voltage Low
60. P0563 Battery Voltage High
61. P0501 VSS Sensor Low
62. P0502 VSS Sensor High/Open..
63. P1356 Rear Cylinder No Combustion
64. P1353 Front Cylnder No Combustion
65. P0444 Purge Solenoid Open/Low
66. P0445 Purge Solenoid High
67. P1475 Exhaust Actuation Position Error
68. P1477 Exhaust Actuator Open/Low
69. P1478 Exhaust Actuator Shorted/High
70. P0131 Front Oxygen Sensor Low
71. P0151 Rear Oxygen Sensor Low
72. P0132 Front Oxygen Sensor High
73. P0152 Rear Oxygen Sensor High
74. P0134 Front Oxygen Sensor Inactive
75. P0154 Rear Oxygen Sensor Inactive
76. P1510 EFI Limited Performance Mode
77. P1511 EFI Power Management Mode
78. P1512 EFI Forced Idle Mode
79. P0577 Cruise Control Input High
1. U1300 Serial Data Low
2. U1301 Serial Data High
3. U1016 Loss of ECM Serial Data
4. U1255 Serial Data Error
5. B1142 Smart Security System Internal Fault
6. B1135 Accelerometer Failed
7. B1136(HFSM) Accelerometer Tip Test Error
8. B1151 Bank Angle Sensor(BAS) Short to Ground
9. B1152 Bank Angle Sensor(BAS) Short to Battery
10. B1153 Bank Angle Sensor(BAS) High
11. B1154 Clutch Switch Input Short to Ground
12. B1155 Neutral Switch Input Short to Battery
13. B1134 Starter Output High
14. B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
15. B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
16. B1123(HFSM) Left Turn Output Short to Ground
17. B1124(HFSM) Right Turn Output Short to Ground
18. B1125(HFSM) Left Turn Output Short to Battery
19. B1126(HFSM) Right Turn Output Short to Battery
20. B1143(HFSM) Security Antenna Short to Ground
21. B1144(HFSM) Security Antenna Short to Battery
22. B1145(HFSM) Security Antenna Open
23. B0563 Battery Voltage High
24. B1131(HFSM) Alarm Output Low
25. B1132(HFSM) Alarm Output High
26. B1141(TSM) Ignition Switch Low/Open..
B1141(HFSM) Ignition Switch Low/Open
To access codes
SP = speedometer
T = tachometer
23. P2123 TGS1 High
25. P2128 TGS2 High
29. P0122 TPS1 Low
31. P0222 TPS2 Low
Here are the codes it is pulling
P0120
P0220
P0223
P1511
P2135
The codes will not clear and the bike will not start. Last time it started was Sunday when we took it off the trailer. It started and ran fine. It sat Sunday night and Monday until after work and now will not start at all. We do have electric and it tries to turn over. It just won't start, idol or anything.
P0120
P0220
P0223
P1511
P2135
Have Sean pull the ECM connector and clean the pins and the plug with electrical contact cleaner. Then put a small amount of dielectric grease on the pins before he reconnects the ECM. There is a service bulletin on which pins are the problem ones but I don't have it. Dawg might be able to help with that, but i just cleaned all of them and put the dielectric grease on. I haven't had a problem since. Maybe 8 or 10 thousand miles ago.
