10,000 mile service
10,000 mile service
my bike is coming up on the 10,000 mile mark. I know that is a factory recommended service interval. I was wondering what all is included in that service? and how much do dealers usually charge for it?
Money is a little tight right now, and i'm pretty decent with a wrench and i have a lift so i'm thinking of doing it myself..
ANy thoughts? advice?
Thanks boys...be well...ride safe
Received 70,366 Likes
This is for a 2007 Touring, but close enough.
Buy the manual and you will save a lot of mula.
Engine oil and filter Replace
Oil lines and brake system -Inspect for leaks
Air cleaner - Inspect, service as required
Tires - Check pressure, inspect tread
Primary chaincase lubricant - Replace
Clutch - Check adjustment
Drive belt and sprockets Inspect, adjust belt
Throttle, brake, clutch controls - Check, adjust, and lubricate
Jiffy stand - Inspect and lubricate
Fuel lines and fittings - Inspect for leaks
Brake fluid - Check levels and condition
Brake pads and discs - Inspect for wear
Spark plugs - Inspect
Electrical equipment and switches - Check operation
Steering head bearings - Lubricate
Air suspension - Check pressure, operation, and leakage
Windshield bushings - Inspect
Cruise control - Inspect disengage switch and components
Fuel door and saddlebags - Lubricate hinges and latches
Critcal fasteners - Check tightness
Engine mounts, stabilizer links - Inspect
Battery - Check battery and clean connections
Road test - Verify component and system functions
Not hard at all. Here is the checklist the dealers use.
http://www.gatewayhd.com/default.asp...ice-checklists
Don't know where in Jersey you are but Liberty Harley in Rahway just did my 10,000 service (09 Road King) for $350. They replaced the rear pads at the same time - $45 for the pads, $15 labor
Their sign above the service garage entrance says $450 for a big twin but they told me that was just the newer? ones. If you're close enough you should check them out. They are fair AND HONEST!
BTW - they used the syn3 in all 3 holes and they have NEVER just inspected spark plugs! THEY HAVE ALWAYS REPLACED THEM! 1,000 & 5,000 & 10,000 mile check ups! I've got 11,000 miles on the bike and I'm on my 4th set of plugs. A bit of overkill but the bike runs like new!
