FM TW-222 Cam reviews needed
Old 08-17-2012, 04:34 PM
roadglider05's Avatar
roadglider05
roadglider05 is offline
I want their dyno to do my bike, it is amazing how their numbers are so much higher than every one else. My 2011 road glide ultra with Boyesen power x intake, V&H power duals, PC-V with auto tune, and Andrews 54H cams on Robs dyno can ONLY achieve 87 hp and 92 lb ft torque and yet even without cams theirs can reach above 100. In lieu of discussion mine were done at 100* and the bike runs better than the #'s indicate. Thank God we don't ride dyno sheets.
Old 08-17-2012, 09:46 PM
punisher660's Avatar
punisher660
punisher660 is offline
Originally Posted by iclick
On another gauge I watch Lambda (AFR) from the WB O2 sensors among others. Very useful.
I'm sure they would be if I knew what in the hell they were. I haven't spent a whole lot of time playing with the Power Vision - how do you do the reset? I scrolled through the menus and didn't see anything.
Old 08-18-2012, 11:23 AM
bklynbob's Avatar
bklynbob
bklynbob is offline
Exactly.......................
Old 08-18-2012, 05:48 PM
7Sixpack7's Avatar
7Sixpack7
7Sixpack7 is offline
Anyone know if the cams are compatible with the stock push rods or do you have to use adjustable push rods?
Old 08-18-2012, 05:51 PM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,365 Likes on 2,619 Posts
Any cam is compatible with stock pushrods if you remove the rocker boxes, adjustables allow you to cut out the stock push rods without having to remove the tank and the rocker boxes.
Old 08-18-2012, 06:19 PM
7Sixpack7's Avatar
7Sixpack7
I read on this forum that the 555's have a smaller base circle and therefore required adjustables (per Jamie @ FM). Was wondering if the base circle on the TW 222 was also smaller.
Old 08-18-2012, 10:31 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
not even close to being true. Only cams with the same base circle or nearly the same base circle can be used with stock pushrods.
Old 08-19-2012, 04:37 AM
Keithhu's Avatar
Keithhu
Keithhu is offline
Ok, thanks and sorry, live and learn, I guess.
Old 08-19-2012, 05:07 AM
equandt's Avatar
equandt
equandt is offline
While the TW-222 makes some nice looking numbers, I'm holding out for the TW-333 cam.
Actually, I'd like to see some comparision to the TW-222 and the TW5-6 cam that woods makes. It kind of looks like you're splitting hairs between the two cams.
Old 08-19-2012, 07:07 AM
sporacer's Avatar
sporacer
sporacer is offline
Really!!! Are you saying they are fudging the numbers???
Quick Reply: FM TW-222 Cam reviews needed
