Take a look at the pic. Rear tire coming apart with about 6,000 miles on it. Made in Brazil. Sent back to Metzler for analysis. Sure glad I caught it on a preride inspection. Could have been bad. Those patches missing go all the way around the tire, just right of the centerline. Should get at least a 50% credit.
Wolver
Holy sh*t!! That could have been catastrophic!!! I've got 880's. I keep an eye on them big time, including the pressures. My rear started to "cup" on the outer tread from low pressure riding 2 up. I started going by their recommended pressure, not HD's and havent had a problem....so far. I think Ive got about 6k on mine right now too. Hmmmmm. I'm glad to hear you caught it before things got ugly!!
This is key! The HD numbers are for the stock factory supplied tires, once you replace any tire go with the pressure on the sidewall of the tire. Even an oem tire may come with a different number if during the manufacturing process the tire mfg can change the spec on the air pressure.
When I went from dunlops to Metzlers there was a 10 lb pressure difference.
