Radio won't turn off after amp install
I installed a PBR300x2 amp and J&M speakers today. Power wire connect to the battery, ground wire connected to the speaker bracket support at the black support, and remote wire hooked up to cigarette lighter power.
When I turn the bike on to make sure everything works, everything works. Problem is when I turn the bike off the radio and instruments continue to stay on and work. Only way to turn off is to remove the fuse from the amp power wire.
What have I done wrong?
Thank you
Thank you
Switch the ground to the battery and still have the same problem. I pull the fuse for the amp and then check the radio staying on after shutting off and it works.
When turning off the bike, the radio and instruments stay on. Only way i can get the radio to turn off is by pulling the amp fuse
