cam help
09-01-2012, 08:17 AM
cam help
I have a 01 Road King. I was planning on changing the cam bearings. Started thinking while Im in there to changes cams. I was looking at the andrews 26 cam. My problem is the engine is stock for now but has a stage 1 air cleaner and free flowing exhaust. I do plan on building a pretty mild 95" later on. Maybe a compression ratio around 10 and port the heads. Would this cam work on both engines?
09-01-2012, 08:18 AM
Is your bike fuel injected?
09-01-2012, 08:26 AM
Guess that is a important peice of info nut no its carbureted. I was also giving a crane cams hi-4tc module that im gonna put on as well
09-01-2012, 09:06 AM
I had s&s 510 gear drive cams in an 06 and I loved how it ran.
09-01-2012, 09:16 AM
Thought about gear drive but already put the ugraded tensioner in less then two years ago and would rather keep it then go to gear drive
09-01-2012, 09:56 AM
Yes, the 26s will work well with 88 or 95 inches and a little compression. Let the experts (not me) tell you what your ideal compression might be.
Randy L. Beckner
03-30-2019 07:24 PM
brawner11
03-27-2016 10:54 PM
Jackpoticorn
09-17-2014 12:17 PM
mooch78
12-13-2012 02:27 PM
BJFLHT
06-03-2011 12:20 PM
