trans mainshaft bearing
I was having a loud rattle coming from the primary when shifting and clutch disengaged so i took it over to the dealership since its under warranty.I was called thursday and told that the rattle was coming from the transmission mainshaft bearing,service guy said it was shot and there was play on the mainshaft and causing the rattle.He also mentioned the inner primary bearing was also shot.The bike is a 2011 streetglide with 12,000 miles on the clock, I was running Amsoil severe gear in trans and Formula plus in primary.Seems like low miles for something like this to happen,and never heard of this with low miles.I did have a tire installed at around 6,000 miles and did notice a chirp on decel and mentioned it to the service guy,he said it was normal.Is it possible that the belt was too tight and caused the bearing to fail?
