recalibrating speedo
Old 09-19-2012, 05:00 PM
yank's Avatar
yank
yank is offline
Default recalibrating speedo
if i change out my wheels to 18" and 26" on my 03FLHT is there a way to recalibrate my speedo?
Old 09-19-2012, 07:09 PM
dawg's Avatar
dawg
dawg is offline
Received 2,962 Likes on 1,714 Posts
Yes. There are a few devices for this. http://www.dakotadigital.com/index.c...cat/cat115.htm
Old 09-19-2012, 11:01 PM
skratch's Avatar
skratch
skratch is offline
Received 4,188 Likes on 2,455 Posts
if you're bike is fi and you have a powervision tuner you can do it with that. some of the other flash tuners as well, though i'm not sure which ones.
Old 09-20-2012, 12:55 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
with an 18" rear you would likely have a low profile tire, no?
then the total height of the tire and wheel might be similar to that of the stock combo.
that should make for a minor difference in the speedo
if your wheel and tire combo is alot higher, you'll need to check clearance inside the fender- it is easier to move the wiring than to have it chewed up on the road somewhere
mike
Old 09-20-2012, 05:06 AM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,364 Likes on 2,619 Posts
If you have a Power Vision, here's a link to how to do it: https://www.hdforums.com/forum/9856988-post9.html
Ston
Shovelhead
07-16-2017 11:54 AM
jeffjackman
The Dark Side
04-05-2017 07:08 AM
joe40x
10-24-2015 12:41 PM
The English guy
09-30-2012 02:06 PM
Anezangl
03-27-2011 02:15 PM
Quick Reply: recalibrating speedo
