Road glide charging problem
Loose terminals? Corrosion at the terminals?
Did you measure the stator output after the bike is started (between it and the voltage regulator)? Did you measure the output at the battery terminals when the bike is running?
http://community.jpcycles.com/articl...g-systems.aspx
first off check the battery.
take it out
charge it on a real battery charger ( not a tender)
then load test it.
- new does not always mean good- it may have failed*.
with a duff battery the charging system checks will give skewed numbers causing you to chase your tail- time and money wasted.
once that checks ok we can continue and see if the charging system is ok or whether something is draining the battery when the bike sits ( which could be a miswired light or other circuit or a bad regulator diode)
mike
*over the years I have had a number of batteries fail. dry cell, wet cell, AGM
take it out
then load test it.
mike
