I'm confused, 95 or 97 Big Bore Kit
I'm looking at installing the big bore kit on my 01 FLHTC. I see I can get the 95" kit for about $499 and the S&S 97" kit for about $795. That's a big difference is cost and I read some where 95" is the highest you can go safely, but S&S has a special way to do it I supposed. I just don't know if the extra 2" in displacement is worth it. Does anyone here know?
Thanks
Thanks
I have the 95 inch kit on my RKC, stage II tune and am very pleased. I believe the 95 kit is bigger bore without stroke lengthening and the 97 is bigger bore and slightly longer stroke. when HD went from 88 to 96, I think what they did was stroked the motor only. Again, I could be wrong. Short stroke with larger bore generally equals more torque at lower rpms and faster revs. Increasing the stroke, increases displacement which can increase HP and torque, but at a slight cost in increased mechanical leverage.
The difference in bore size between 95, 97 and 98 kits is actually quite small. A 95 kit has 3.875" bores, giving 94.34 cu in; a 97 kit has 3.927" bores, giving 96.89 cu in; a 98 cu in kit has 3.938" bores, giving 97.44 cu in.
You can see that the difference in size between a 95 and 98 is just 1/16" on diameter and that some artistic license is used in what size they actually give.
Rick
