New cam, lifters, pushrods and now rocker knock?
I reduced my engine noise doing these things: put in Smith Brothers adjustable pushrods, Headquarters lifters, Baisley spring, new S&S rockers and shafts. The new rockers reduced end play from .016 to .007". I also went to Castrol GTX oil (was using Amsoil before). My bike is a 107 with Andrews 54H cams. Runs pretty quiet now.(Rockers are non-roller)
Really like them. I had posted a while back in thinking I would push the motor out to 95". But after these cams were installed there is no need.
Really woke the bike up! I'm not a "speedster" on my bike, just like to put on good cruising miles. But it sure is fun throttling thru the corners and feeling and hearing the motor "dig in" and pull!
Now I just wish I didn't hear the top end ticking when I'm cruising.
Based on all the replies, I think I'm going to upgrade the oil pump/pressure this winter.
Hopefully more oil pressure will quiet it down?
pmcburne: You have me thinking when you mention S&S rockers? Outside of oil pressure, I'm curious as to what condition the rockers are in the top end?
Hello, I also recently did cam chest work, 21 cams, Baisley Spring and seat, S&S lifters and adj pushrods, cyco shoes,
My bike was noisy before and it is noisy now. Funny both Road King I have had were 2004 and noisy top ends. I just try and forget about it. Mine is not constant and as the bike warms it becomes more prevalent. Also most noisy around 55-60 MPH in 5th At higher rpm it quiets down. Been using Mobil 1 synthetic for years, maybe different oil will cure it but who cares.
BTW I also went with the Auto tune with a PCV all from fuelmoto and after a couple tuning sessions this bike runs incredibly good, crisp and no popping ever. I was surprised at how much difference the tuning runs made ! On the first ride I was pretty disappointed in my results.
Put in new Andrews tw21 cams with new lifters and after couple hundred miles brought it back with the upper rockers ticking/knocking. The mechanic replaced with another set of new lifters and adjustable pushrods. The rocker noise subsided slightly but is still there.
Interesting thing is, it is intermittent. Sometimes there is no rocker noise at all, sometimes they tick and sometimes it knocks. All can happen within 1 mile of cruising. Speed, rpms, on & off the throttle doesn't seem to make any difference.
Anyone have any idea of a fix? Would an upgraded oil pump help with lifter pressure?
Any ideas are extremely welcome!
BTW: I am running HD SE synthetic oil and have been since new.
2001 RK with 70k miles
Notation:
Several thousand miles prior I changed the lifters and went to adjustable push-rods which did nothing but cost me $.
Or the original video where I found the source of the noise...
__________________
NO, they DON'T all do that!
Also on amazon.com...
My 103 has considerable lifter/valve train noise. I chased it around for a while, installed the rocker lockers, and upgraded from Delphi to Johnson lifters, ran the plungers deeper in the lifters, etc, but the noise remains.
I did help it some, but the cams create considerable noise, loudest in the 2200-2700rpm's range.
I've just learned to deal with it, and put enough miles on the engine at this point that I know it's not hurting anything, just going to be the "nature of the beast".
I felt even better about the whole deal when I put the bike on they dyno at a local event, and it cranked out 103hp/103tq, with over 100ft lbs torque across a good portion of the rpm range and torque curve nearly as flat as Kansas!......Cliff
