Security system - motion alarm question
On a '05 RG, I picked up a couple years ago , I finally decided to play with the security system. I had never used it before. Both of the key fobs activated the system OK and wouldn't let me start it. Then I thought it would be usefull to have an audible alarm( I have an aftermarket one on my soft tail and it works good.).
So I run down to the HD shop and pick up a siren kit, install it and play around some more.
If I activate the system and then turn on the key, the siren goes off and continues uninterrupted. Just as I would expect ( I assume it turns off at some point, but I didn't want to blast my ears out till it did, so I pushed the key fob to turn it off)
Next, I rearmed the system and sat on the bike and lifted it off the sidestand. The siren chirped once and that was it. Not much of a deterent. I had expected it to go off in a continuous manner.
How is it supposed to work ? Is there a setting I need to change/activate ?
When it gets old you need to shake it a few times.? HA. There is a setting for levels of sensitive. (3 or 4 of them) One will let you friends exhaust set it off. It's probably were it needs to be since you will forget your alarm is buried in you pocket and it's hard to get it out with both hands on your ears.
Sorry T, I hate it when it take me two minutes to type what someone just said..we think the same. You must be rich like me.
I would tell you but it took me 8 years to figure out how to set alarm to just a push left signal right signal 5 times to disarm. For some reason when I try to key mine into setup mode after about 3 or 4 tries it finally works. The new button-less one is probably worth a new Harley.
