Oil Temp.. What is yours?
Old 08-10-2005, 01:25 PM
Crimson's Avatar
Crimson
Crimson is offline
Default Oil Temp.. What is yours?
I just purchased an LCD Temp Oil Dipstick for my 96 EVO Roadking Classic, and it seems like my temps are lower than they should be.. But I'd like some input from others on what they get. Especially if you have the dipstick... I'm trying to figure out if its accurate or defective or what.
Yesterday I took a 10 mile ride to test it out, I took it out on the interstate for maybe 7 of those, then back home.. when I got home I checked the temp and it was around 193 degrees.. which seems low from what others have told me.. The temp outside was mid 90's, so it wasn't COOL.
This morning I rode to work, which is only about 2 miles, and the temp only showed 110 degrees. It seems to me like it would warm up MUCH quicker than that.. but maybe I'm wrong.. it was cooler this morning, maybe 70 degrees.. or maybe its not showing the right temp?
Do these temps seem plausible to people or is this thing defective? I'm not sure how quickly oil heats up.. do I need to ride for an hour before I see the 200+ degree temps most people get?
Old 08-10-2005, 01:36 PM
Big Ted's Avatar
Big Ted
Big Ted is offline
Default RE: Oil Temp.. What is yours?
I am no expert, but I don't think you would get a good reading in just a 10/15 minute period. I would think that a longer ride is in order to see a REAL temp reading.
Old 08-10-2005, 02:00 PM
skywagon's Avatar
skywagon
skywagon is offline
Mine reads at 90 outside temps, 1/2 to 2 hours run time, 206-210 70 degrees outside temps, 1/2 to 2 hours run time 190-196 full synthetic oil of a popular brand 20/50 wt.[sm=smiley20.gif]
Old 08-10-2005, 02:01 PM
Markcuda's Avatar
Markcuda
Markcuda is offline
I can ride mine for a 1/2 hour at 70 MPH and it is still climbing.
Coming back from Sturgis 2 days ago, I was seeing 252 on my guage, digital guage.
That was at 80 MPH across South Dakota with temps. well in the 100s
Old 08-10-2005, 04:11 PM
jlacasci's Avatar
jlacasci
jlacasci is offline
Hi,
I'm on my second LCD dip stick. Got mine because my bike runs HOT, although the dealer says all is fine. Folks here said the stick's are know to be off quite a bit. So I boiled mine along with a analog and digital meat thermometer. The LCD was ***** on accurate and my bike never runs much cooler than 247. If it's hot out, around 90ish and I run her for 30 minutes or so at around 70 - 80, she'll climb up to 260.
My original LCD had some moister problems and I couldn't read the temp too easilly, brought it back to one of the good dealers I do business with and they exchanged it. Told me they've had a couple others returned for the same reason. Anyway, boiling this one showed the temp to be around 4 to 5 degrees too low. On my recent trip to NC the temp was up near 270 at times.
When I had my stage 1 put on the bike was dyno'd and the dealer said all is running perfectly, she just might like to run a bit warm.
Joe
Old 08-10-2005, 04:15 PM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
My 95 runs around 225-235 most of the time
Old 08-10-2005, 06:09 PM
Crimson's Avatar
Crimson
Crimson is offline
Thats a good idea, boil some water and see what it registers.. I will do that. I assume it will read approximately 100C or 212F when I stick it in boiling water?
Old 08-11-2005, 01:06 AM
cash's Avatar
cash
cash is offline
Boiling point depends on the barometric pressure and if you live at higher altitudes the boiling point is going to be lower. Rough approximation is that if you lived in Denver at about 5000 feet altitude water would boil at 202-203 degrees F. It is a rough approximation but figure about 212 minus 2 degrees for each 1000 feet altitude.
T
Old 08-11-2005, 01:21 AM
mikeisglidn's Avatar
mikeisglidn
mikeisglidn is offline
my sporty runs around 205-210 2 hour ride at about 70-75
Old 08-11-2005, 01:22 AM
Markcuda's Avatar
Markcuda
Markcuda is offline
Ok, I have a Dakota Digital guage in my Ultras dash.
If the guage reads 252* at 3500 feet, would that be the same as 252* at 500 feet??
Or am I getting a differant reading as I drive higher or lower elavations??
Quick Reply: Oil Temp.. What is yours?
