Sandy taketh away
Sandy taketh away
:'( Hey guys Sandy was a kick in *** for everyone in the NE here. I'm in Brooklyn, SI New drop, and Rockaway areas got hit hard. I guess if you can read and write on this it's not so bad compare to others.
My question is my 09 and 06 where in 3-4 feet of water in the garage, can they be saved? I really don't want to scrap them. The insurance will never give me aha I put in them. Can they pay me top dollar to fix them?
I dont know shiiittt right now :-\ :nixweiss:
I know I have my life and family, but I'm stuck with this trash now.
Trey
Trey
Hi from across the pond. Sandy got wall to wall coverage over here and it looked unbelievable what you have all been through. Very best of luck getting ordinary life sorted out.
As for your bikes, I'm sure they could be recovered, however just how far water damage will have got is so uncertain. Thinking on my feet, the worst case I can imagine would be if water got inside the engine and trans, so you could drain them both to see what state the oil is in. If it is clean and uncontaminated there may be hope, if you get out a horrible slurry, you probably have your answer.
Fingers crossed......
+1 - the Insurance company will total them anyway, as repair cost would exceed the value of the bikes in all likelihood. Start researching values so you can have input into establishing what your bikes are worth. In times like these, insurance adjusters want to move claims. If you are reasonable and have information to support your position, they will (or should) listen.
Received 47,785 Likes
I feel your pain - chances are I would try to fix it myself too. But keep in mind you have salt water in EVERY electrical connector on that bike. Your grounds are all going to be in horrible shape, you will likely have all kinds of random electrical gremlins from the bad connections all over the place. You would really need to disassemble every connector (removing every single pin), remove all the salt and corrosion, and reassemble all the connectors. Do the same with all of the ground points. Who knows what the ECM connectors look like - not nearly as easy to clean the corrosion off of either.
Who knows where the salt water made it inside your frame, past various bearings, where it's going to rust through eventually.
Going through the engine itself should be pretty easy, just have to completely drain all three holes, flush them out with cheap fluid, and go from there. But I think the electrical issues are what's going to kill you here.
Sorry to here of all that you folks went through out east. Do you know if your insurance company will let you buy it back? Not sure if that works with bikes, they use to let us buy totaled cars back for the salvage value, then we would sell parts off them to recoup some of the loss that insurance didn't cover. Not sure what extras you have on your bikes, some of them may be reusable/salvageable.
A buddy had a pickup ('60's dodge) go through the ice in the winter (Ice was thick enough - it shifted and a crack opened up), pulled it out and changed the fluids right away and had it running in a couple hours - before any rust set in. It was an old plow truck so things like dash lights didn't matter. Also still have a chain saw that went through a flood, still runs great (changed fluids and dried it out ASAP). The problem you would run into is with anything electrical and if it has been sitting for a week now - plus salt water...
