Difference in Touring Mufflers 84-94 & '95+
Received 47,785 Likes
I can tell you that up through 1992 they used a flanged type of inlet on the muffler ..1993 and later they went to a slip fit on the inlet of the muffler .... You can use the later model head pipes ( not sure of the specific years ) on some of the older bagger models which would mean that you could use the slip on style muffler system on the ( some ) 1992 and earlier scooters
The difference as stated is the way the muffler and pipe are joined and clamped to each other. I have an 08 system on my 1990 bike, so pipes up to that year will fit, along with any mufflers up to that year. My 08 pipes have O2 sensor ports, which my tuner likes to use for setting up.
If you cut off the flared part of your early pipes you should find you can fit later mufflers. Your mufflers fit inside the pipes, later ones fit over them.
FenderGuy53
05-26-2016 03:14 PM
