Scream Eagle Tuner or Power Commander
Old 11-30-2012, 10:17 AM
Brusier1028's Avatar
Brusier1028
Brusier1028 is offline
Default Scream Eagle Tuner or Power Commander
MY Bike came with a power commander and I was given a SC tuner for free unused sealed in the box. What would you use and why?
Old 11-30-2012, 10:24 AM
mgmmgm's Avatar
mgmmgm
mgmmgm is offline
Sell the SE tuner on eBay get a PowerVision from Fuelmoto.
Why? Check out Fuelmoto site regarding the PV.
Cheers,
Mark
Old 11-30-2012, 10:36 AM
CHIPPDOG77's Avatar
CHIPPDOG77
CHIPPDOG77 is offline
Get ready to be confused. There are gonna be this percentage like this cause they had problems with that,and a percentage that like that because they had a problem with this. Never ending debate like oil. Run whats on the bike,if you need the money sell the other. If money isnt an issue,stick it in the closet for "if" the other one dies.
Old 11-30-2012, 10:40 AM
bobgv's Avatar
bobgv
bobgv is offline
Get a Power Vision!
Old 11-30-2012, 10:49 AM
TUCCI's Avatar
TUCCI
TUCCI is offline
The screaming eagle is a Harley download tuner.... The power commander has the ability to be adjustable via a laptop computer... The power commander you can pretty much do what you want with it including the timing... The Screamin Eagle tuner you're at the mercy of the dealership so you have to decide which way you want from there
Old 11-30-2012, 10:54 AM
Grillfish's Avatar
Grillfish
Grillfish is offline
What SE tuner is it? SE Pro or SE Street tuner? Either way, if your bike is running good, you can sell the SE tuner and keep the PC. Or, sell both and pick up Power Vison from FM. Or sell the PC, if it's the SE Pro, buy cables and program disk and go tune it yourself.
You got options, which is nice to have.
Old 11-30-2012, 10:56 AM
golfblues's Avatar
golfblues
golfblues is online now
Received 1,434 Likes on 874 Posts
If your bike runs well with the PC keep it as is. No need to screw with a good thing.
Old 11-30-2012, 11:28 AM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
PC is a fuel management device only that has to remain on the bike.
SE Tuners are full blown tuners that allow the manipulation of almost all aspects of air, fuel, timing, etc and write that program to the ECM (provided the one you have is the SEPST or SERT) and nothing stays on the bike.
2 totally different beasts and both more than capable of doing what they're designed to do.
Old 11-30-2012, 11:46 AM
Bugsy's Avatar
Bugsy
Bugsy is offline
+1 on Power Vision
As previously mentioned, if the bike is running well why change anything? If you're planning on some mods, that's a different story. In that case if it's the SE Pro tuner I'd probably keep it and use it, if it's the street tuner I wouldn't waste my time with it -- it's too limited b/c it has to stay within EPA guidelines.
I went with the Power Vision recently and I love it! It's so easy to use and can do so much!
Old 11-30-2012, 12:25 PM
bohica48's Avatar
bohica48
bohica48 is offline
IMHO the PowerVision is the way to go, very user friendly.
Quick Reply: Scream Eagle Tuner or Power Commander
