Those 2 whip antennas
12-05-2012, 05:41 PM
What the heck holds the two big whip antennas on the tour pak of my 07 EGU? I thought they were just screwed in. Do I have to put a pair a Vice Grips on them to unscrew them or is there some trick. My manual doesn't have squat about it. It's a Clymer but it's all I have.
12-05-2012, 05:52 PM
Put your specs on and take a closer look.
At the base of each antenna is a small allen head set screw that must be loosened before turning the antennas counter-clockwise to remove.
Be sure to make them "Right" or "Left: before removing them.
12-06-2012, 05:09 PM
Quote:
Originally Posted by
2AMGuy
Okay, is this allen screw on the inside or outside the box? If it's inside I may have a problem. One of the acorn nuts just spins. Not sure what I'm going to do about that.
12-06-2012, 06:26 PM
Are you trying to remove the complete ant. or just the whips?
12-06-2012, 07:00 PM
2AMGuy
Wha??? I just twisted mine off and put the shortys on.
12-06-2012, 07:06 PM
That's what I'm thinking too Kiethhu, what am I missing?
12-06-2012, 07:08 PM
mine just twist off no set screws 12 ultra classic
12-06-2012, 07:34 PM
Newer bikes just twist on and off. Older years have set screw noted. Changes made due to revised loading methods used on more recent bikes.
12-07-2012, 04:30 AM
skeeter 250
Just the darn whips.
12-07-2012, 08:43 AM
2010 just twisted off, no set screw.
