Info on dyno
It all depends how good the map was...
If you used all standard parts and SS supplied the map then it is probabbly pretty good. If I Hi Po speciality shop like Fuel Moto supplied the the map then it is probabbly pretty good.
On the other hand if your shop just used a standard canned map that was kinda close then you are leaving alot of performance on the table. Or you might get good performance with poor fuel milage or lots of pinging.
The real answer is "it all depends...."
I run a canned map from fuel moto but my motor is stock minus the exhaust pipe and it runs like a raped ape. I will dyno it in the spring to see how the AFR curve looks and what type of performance I am getting. IMO if you just paid for all those upgrades, spend the xtra change to make sure you're squeezing it for top performance.
Just be sure a competent tuner does it. Ask around for recommendation.
Nicky Pass
12-22-2011 07:46 PM
