Good, Better, Best Heads
Old 12-19-2012, 03:36 PM
Mr HOG's Avatar
Mr HOG
Mr HOG is offline
Originally Posted by d-roadglidr
Thinking about cams and heads for.my 06 TC88. I think Andrews 26 cams, but I want to put new heads on to take full advantage of them. I'm leaving the bore alone for the time being, but I have cylinders available for boring later. Friends tell me I'd be happy with heads and cams.
Question is, which heads? And what is HTCC?
I'm after torque and power up to around the 4500 mark. I ride two up most of the time on a RG.
You are thinking of changing cams and doing head work but leaving the stock bore? Why would you want leave out the cheapest step to gaining more HP? The heads also need to be set-up for your cam and engine configuration. If you even think you might want/need a bigger bore then do it all at the same time. Otherwise, it's going to cost you a lot more to do the bigger bore later.
  #42
Old 12-19-2012, 04:44 PM
RalphDBS's Avatar
RalphDBS
RalphDBS is offline
Jim's house of Harley in Putnam, Ct
  #43
Old 03-04-2020, 08:24 PM
Roadglide2234's Avatar
Roadglide2234
Roadglide2234 is offline
Stage II
Default 3.875 HTCC pistons
[QUOTE=Scrmnvtwins;10661445][quote=d-roadglidr;10660556]
Quote]
HTCC = High Torque Compression Chamber and is a line of Screamin Eagle parts. If you purchase the HTCC heads, you must purchase the HTCC Pistons and you must purchase the HTCC Intake to work with the D port intake.
When I built my '03 Twin Cam I created the following spreadsheet to help me decide where I wanted to be and how much it would cost me. May be neneficial for you to try something like this....
Build
Pistons
Heads
Intake
TQ
HP
Comp
1450 Stock
Stock
Stock
Stock
70
58
8.8:1
1450Stage I
Stock
Stock
Stock
81
72
8.8:1
1450Stage II
Stock
Stock
Stock
88
74
8.8:1
1450 Stage IV HO
HC Forged - 22864-00
Perf - 16952-99B Black
95
90
10.5:1
1550 Stage I
Flat Top - 22851-99A
Stock
Stock
89
75
8.8:1
1550 Stage II
Stock
Stock
96
81
9.4:1
1550 Stage II - Perf Hds
Perf - 16952-99B
Stock
98
82
10.0:1
1550 Stage III
HC Cast - 22661-99A
Stock
Stock
99
82
10.25:1
1550 Stage IV (HO)
HC Forged - 22868-00
Stock
99
94
10.5:1
1550 Stage II HTCC
I’m doing a build for a customers 2004 road king custom with SE HTCC heads SE pushrods, Lifters, Oilpump & cam plate upgrade as well as S&S .585 cams ( not sure if we are Gna used those cams) but I’m in search of the HTCC pistons. He is determined to use this setup as he has $0 invested and all parts are brand new and given to him by his brother.
any help on finding the pistons or thoughts in general would be appreciated. Thanks
  #44
Old 03-04-2020, 08:37 PM
memphisharley's Avatar
memphisharley
memphisharley is offline
[QUOTE=Roadglide2234;18923340][QUOTE=Scrmnvtwins;10661445]
Quote]
BuildPistonsHeadsIntakeTQHPComp1450 StockStockStockStock70588.8:11450Stage IStockStockStock81728.8:11450Stage IIStockStockStock88748.8:11450 Stage IV HOHC Forged - 22864-00Perf - 16952-99B Black959010.5:11550 Stage IFlat Top - 22851-99AStockStock89758.8:11550 Stage IIFlat Top - 22851-99AStockStock96819.4:11550 Stage II - Perf HdsFlat Top - 22851-99APerf - 16952-99BStock988210.0:11550 Stage IIIHC Cast - 22661-99AStockStock998210.25:11550 Stage IV (HO)HC Forged - 22868-00Perf - 16952-99B BlackStock999410.5:11550 Stage II HTCC
may want to start your own thread...this one is 8 years old.
good luck!
94 ultra
Engine Mechanical Topics
16
12-22-2015 06:31 AM
txphatboy
Exhaust System Topics
20
04-16-2013 07:47 AM
FL-kruzen
04-10-2013 08:21 PM
Joker65
01-30-2012 06:51 PM
HD Renegade
04-16-2009 04:01 PM
Quick Reply: Good, Better, Best Heads
