'11 SG, check your front plug wire
I have the SG tore down for winter projects. Fairings, front forks, handlebars and tank are off at the moment. This bike has just under 15K on it.
My post is about the front plug wire. I was shocked to see my front wire was almost wore through to the core from rubbing against the tank. You could not see it normally. With the tank off I spotted it instantly. Mine was looped up under the tank, then into the zip tie.
If it was happening on mine, there is a chance it is happening on someone elses. I think by running your finger along the plug wire you should be able to tell without pulling the tank.
Plug wire was never moved since I bought the bike. This is the way it came down the line.
Once it warms up alittle, I'll check mine.........just to be sure
