Need help with the shifter shaft assembly.
I had the inner primary off to change the trans pulley. The manual isn't too specific on with the shifter shaft assembly. Is this right.
1) Shifter lever
2) rubber spacer
3) inner primary
4) shifter rod bracket
5) shifter linkage
It seems like something should go between the inner primary and the shifter rod bracket? Real surprised there isn't a picture in the manual.
1) Shifter lever
2) rubber spacer
3) inner primary
5) shifter linkage
Nothing goes on the inside of the primary and the shifter arm? It seems like it would just rub on the inner primary without a washer or something. I don't remember anything being there when I took it apart. The rubber spacer cannot go on the inside because the shifter rod would hit the engine!
