SE heads & 259E cams
I had them on a 103 and was surprised with the performance even with the stock pistons.
Depending and what heads you go with, you'll actually drop the compression ratio if you do not install high compression pistons.
Getting your stock heads reworked with the 259e cams would be a lot cheaper and you can keep your stock pistons if you have low mileage.
RK14SGS
2014-2023 Touring Models
13
01-19-2015 05:06 PM
XfasteddieX
Exhaust System Topics
09-16-2006 10:56 PM
