"Harley Lube" Equivalent
Old 12-31-2012, 03:30 PM
NPW's Avatar
NPW
NPW is offline
Default "Harley Lube" Equivalent
What is the equivalent to "Harley Lube" for cables, hinges, ect.?
Old 12-31-2012, 03:42 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
for clutch or throttle cables, I buy a can of cable lube ( green can) with a cable luber attachment, you can shoot the lube right through the cable...I've had the same can for over 30 years.
for hinges etc white lithium greases is handy although i use a clear "teflon" lube from harbor freight ( gray tube)- radio shack used to carry the same stuff. it stays in place even when hot.
I use it at work so I always have some around.
I use hi temp bearing grease on stuff like the old brake linkages on the panhead- it sticks and repels water
whatever you use, apply sparingly, wipe off any excess or overspray
mike
Old 12-31-2012, 04:43 PM
NPW's Avatar
NPW
NPW is offline
Thanks Mike. I was just wondering if anyone knows what the "civilian" equivalent of what the service manual refers to as "Harley Lube" is.
Old 12-31-2012, 06:24 PM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is offline
Received 1,562 Likes on 1,082 Posts
Kentucky lube, otherwise known as KY. Manufactured by Johnson & Johnson.
Old 12-31-2012, 08:39 PM
Retrop's Avatar
Retrop
Retrop is offline
Chainsaw bar oil.
Old 12-31-2012, 09:50 PM
Pondskipper's Avatar
Pondskipper
Pondskipper is offline
If you do not use moco lube then your warranty is voided.
Old 12-31-2012, 09:54 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
Don't let your wife find a tube of KY jelly in your luggage. It won't turn out good.
Old 01-01-2013, 12:35 AM
drukanfu's Avatar
drukanfu
drukanfu is offline
Refined Caviar !
Old 01-01-2013, 08:38 AM
psychocircus's Avatar
psychocircus
psychocircus is offline
KY!____________damn, someone already said it!
Old 01-01-2013, 11:31 AM
NPW's Avatar
NPW
NPW is offline
Funny how lack of ***** makes everyone a comedian.
Quick Reply: "Harley Lube" Equivalent
