If you would work for HD
Old 01-02-2013, 01:03 PM
Pete6114's Avatar
Pete6114
Pete6114 is offline
Default If you would work for HD
If you would work for HD and had the opportunity to engineer and design, what would you change?
Old 01-02-2013, 01:17 PM
sgt. slaughter's Avatar
sgt. slaughter
sgt. slaughter is offline
Modern front suspension, aluminum frame, wheels that weigh less than the ones on my car, rear suspension with some travel.
Old 01-02-2013, 01:19 PM
Cowboy Rob's Avatar
Cowboy Rob
Cowboy Rob is offline
Big Kahuna HDF Member
Received 2,565 Likes on 1,497 Posts
Ergonomic changes,it's a shame someone over 6' tall has to feel this cramped. I'm convinced HD designers must be a bunch of skinny midgets.
Old 01-02-2013, 01:24 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
bring back Buell.
Mike
Old 01-02-2013, 01:28 PM
Fast Aire's Avatar
Fast Aire
Fast Aire is offline
Former Sponsor
Re: Modern front suspension, aluminum frame, wheels that weigh less than the ones on my car, rear suspension with some travel.
- Inverted front forks w/ adjustability
- Lighter frame for sure - put the whole bike on a diet
- Front / rear brake biased valve operated by front lever
- Change oil filter mount so it doesnt make a mess when changed
- Balance the engine components better, time for the shake & buzz to go away
- Top & bottom steering neck zerk grease fittings
- OEM LED lighting for run, brake & turn
Just for starters
Old 01-02-2013, 01:29 PM
Molarman's Avatar
Molarman
Molarman is offline
A model line with water cooled engine for touring.
Old 01-02-2013, 01:33 PM
mikesth's Avatar
mikesth
mikesth is offline
Take out the 'stupid' - start with the 28 spoke wheels that you have to struggle to check the air.
Old 01-02-2013, 01:34 PM
Fatboy Brian's Avatar
Fatboy Brian
Fatboy Brian is offline
I'd change the rear suspension (adjust-ability), would also make the ride height somewhat adjustable to allow for different size riders. Install a factory oil temp gauge.
Old 01-02-2013, 01:39 PM
Pioneer74's Avatar
Pioneer74
Pioneer74 is offline
Upgrade hinges standard. Aluminum frame.
Sc0-'s Avatar
Sc0-
Sc0- is offline
A parts list of everything that is made overseas and switch to domestic components, includes all Harley labeled products.
Quick Reply: If you would work for HD
