Where to install secondary fuse panel?
Thinking of adding a supplementary fuse panel to clean up the extra wiring from the battery terminals. There doesn't seem to be a clear spot under the seat besides the void in front of the battery. Can't really get at it there. I've considered mounting it inside the fairing. Does that make any sense? Has anyone mounted one of these?
10 is good, stranded wire- not solid.
and the fuse as close to the battery as you can - the fuse value should be closely matched to the load
there is a danger of chafing the insulation, I slide tubing over my added wiring ( similar to a heat shrink tubing, but thicker) just in case.
mike
mike
Have look here: http://www.easternbeaver.com/Main/Wi...fuseboxes.html
Agreed next to the exsisting fuse pannel or in the fairing.
Good luck.
Good luck.
