Removing a Dash Insert
Old 01-08-2013, 10:34 AM
Da Shadow's Avatar
Da Shadow
Da Shadow is offline
Default Removing a Dash Insert
Hey Guys,
This may be a dumb question but I ordered a pro one ball milled dash insert for my 2011 FLHTK and it will be here in a couple days. How do I get the stock insert off of the dash? I know how to get the entire dash off of the tank from an earlier experience running some wires under it but am not sure about removing the insert I am replacing. Thanks
Old 01-08-2013, 10:35 AM
jimsflh's Avatar
jimsflh
jimsflh is offline
take the dask off again, you will see it
Old 01-08-2013, 12:00 PM
Rickr01's Avatar
Rickr01
Rickr01 is offline
I had my wife pry up a corner of mine with her long finger nails then I ran a light weight fishing line under the insert. Just a couple of saws back and forth with the line gave me something to easily grab a hold of and off it came with a hard pull. Cleaned up the old glue with WD 40 and a little Goo Gone. Just remember to wipe it down good with something like alcohol before sticking the new one on. They don't adhere well to oily surfaces..LOL
Old 01-08-2013, 12:02 PM
Scrmnvtwins's Avatar
Scrmnvtwins
Scrmnvtwins is offline
The insert is held on with adhesive. Borrow the 'ol lady's hair dryer and heat the insert up real good, it will pull right off and leave no adhesive behind
Lyntis (04-26-2023)
Old 01-08-2013, 12:26 PM
Da Shadow's Avatar
Da Shadow
Thanks Guys. I thought it was adhesive but I would rather ask than break something........
Old 01-08-2013, 01:06 PM
mikesth's Avatar
mikesth
mikesth is offline
Used a heatgun on low - same as the hairdryer method when I was doing my Ironglass insert. Ted provided instructions. You will distort the insert so don't plan on going back.
Old 01-08-2013, 01:15 PM
FXR_Hamster's Avatar
FXR_Hamster
FXR_Hamster is offline
Maybe post a pic of the new one installed ?
Old 01-08-2013, 01:32 PM
craigffb's Avatar
craigffb
craigffb is offline
I was able to reuse the one on my Street Glide after I took it out to get the dash powder coated. Was careful when I too it off that's all.
mike14_07
09-05-2015 06:43 AM
rowle
05-11-2015 07:18 AM
fenwick
02-03-2015 09:54 PM
WARG
08-11-2010 11:27 AM
gottahavvitt
03-27-2008 07:08 PM
Quick Reply: Removing a Dash Insert
