Security Light (Red Key) Comes On While Riding
I have the Custom Dynamics LED turn signals and load equalizer. In the instructions it states that the load equalizer balances the load or draw of the LED lights due to a lower amperage draw of the LED's vs. incandescent bulbs. The load equalizer slows the blink rate of the lights to the flasher's blink rate (slower). It also serves the purpose of eliminating trouble codes sent to your ECM if you are running with no load equalizer. I suppose it is possible.
i had this happen on my 12 CVO RG, start up the bike, red key come on red key go off, then about 10 seconds later, red key back on and stayed on. i always do the walk around and check all the bulbs lights and horn before jumping on the bike so i was puzzled as to why the lite was on. .turned out i had a front turn signal bulb that was working sometimes and not others, only figured it out when i went to make a left turn and the left blinker flashed more rapidly than the right blinker. Pulled the bulb, replaced it with new bulb and the red key light went out.
When I switched to LED turn signals on my bike, the parts guy and the tech (I asked them both about HD or non HD lights) both warned me that non HD systems need a load equalizer or I would experience exactly what you described. I realize others may have offered similar response, but I hope this gets to the point. I hope you have good luck getting it resolved.
Here's what I found out:
I installed 1157 type LEDs (front amber, rear red) from SuperBrightLEDs. $30
I also installed 4 smoke bullet lenses. $10
The red key light would come as soon as I tried to use the turn signals. The signals appeared to work normal, but the red key would come on. If I didn't use the turn signals the red key would not come on.
I installed a Custom Dynamics load equalizer (stabilizer), and now everything works perfect. No more red key light.
