Air Cleaner Question
Happy New Year Everyone!
I just have a minor question regarding my air cleaner cover. I have the Vance & Hines Naked O2 Air Cleaner with Stock cover. I thouht I would be OK with the stock cover but as it turns out, I'm Not. I ride in pretty much all types of weather and am concerned if I remove the stock cover and just put on a trim plate, is there a concern for water on/in the exposed filter elimate when I ride in the rain or even if the bike is resting in a parking lot in the rain?
Thanks in advance.
Thanks in advance.
RE: Air cleaner in the rain
I have the Kuryakin High Five Mach II Air Cleaner, which has an exposed filter element. I was concerned about your very question, and called Kuryakin and talked to their tech on two occasions. Both of them stated that as long as the filter is oiled as instructed, there should be no issues with water ingress.
The stock type cover hides this.
with out which you would either see ugly plug or need some kind of cover at about 7 o'clock on the TB
Mike
