Decat Pipes
Old 01-20-2013, 03:43 PM
hardheaded's Avatar
hardheaded
hardheaded is online now
Received 2,481 Likes on 1,540 Posts
Originally Posted by chainsaw123
In my opinion, what you guys are doing is merely drilling a hole in the cat material. Having cut a panel out of my cat, I dont see any way at all that you have all the material out, not even close. With my panel removed, I had to chip, tear, scrap and grind ALL of the material out so that when I had the panel welded back up the surface was devoid of any little strips of the metal catalyctic material. I could imagin that leaving so much material that you would be leaving "could" possibly cause metal on metal tinny sounds as the exhaust pulses through the chamber.
Just my 2 pennies worth. Do as you want to your bikes.
no it does'nt leave anything in the pipe, just keep running the bit in and out of the pipe againest the walls and it gets it clean. you can look in there with a light and mirrior and see thats it's clean, not like you polished it but pretty clean. done this on 4 bikes, same results. i have 2 welders at home but didn't see any need. do a search on here there are many people who have drilled their cats out. i did'nt think you could drill it out at first either until i gave it a try works very well. do it anyway you like just don't breath the dust it kicks up.
Old 01-20-2013, 04:04 PM
fat daddy's Avatar
fat daddy
fat daddy is offline
Hey JD I have a stage 1 screaming eagle breather $ 140.00 29260-08 and a Vance & Hines Skullcap insert $ 50.00 jp cycle part #404-538 pretty nice setup and it will get ya started if ya want um I'll take $85.00 shipped,and no you won't have to get a tuner for your bike.getting rid of the cat is the best thing you can do for your motor you won't believe the difference in the heat. Good Luck
Old 01-20-2013, 06:24 PM
o-townFLA's Avatar
o-townFLA
o-townFLA is offline
I also decatted my own head pipe and I don't think a hole saw will get all the material out either. Even with a window cut it took some effort to remove all of it...
Slip-on's and a flowing head pipe shouldn't need a fuel management system. But all bikes are different. You will enjoy less heat and more of a rumble with just the stock slip-on's.
Old 01-20-2013, 07:28 PM
trispeed's Avatar
trispeed
trispeed is offline
yep, getting rid of the cat will do nothing for performance or heat (while you're riding). Look at it, it's below and behind your feet, how can you get ANY extra heat when riding??Air flow will move the heat back behind you, right?
I can't feel it at all (2011 FLHP) but I wear boots and long pants; if you're gonna wear flip- flops and shorts, ANY bike is gonna roast you. Just sayin' :-)
Old 01-20-2013, 07:35 PM
o-townFLA's Avatar
o-townFLA
Metal is conductive. So if the catalytic converter is doing its job by heating up to burn off unused carbons, the heat produced from the cat will travel up/down and all around the rest of the piping...
Old 01-20-2013, 07:43 PM
jay87LX's Avatar
jay87LX
jay87LX is offline
huh??
The cat in the very instance of its design and intention is to get so hot that it burns off any excess fuel not burned in the combustion process, getting rid of that material, whether by taking it out of the stock headpipe of an aftermarket hadpipe will reduce heat.
Old 01-20-2013, 10:04 PM
pontiac69's Avatar
pontiac69
pontiac69 is offline
Trust the ones that did it with the paddle bit. It removes everything. Until you do it you will never agree i guess. Probably even with a pic you wont agree.
Old 01-21-2013, 12:32 PM
trispeed's Avatar
trispeed
trispeed is offline
Originally Posted by jay-s
huh??
it won't help performance in any measurable way; there's no proof anywhere in the great wide world of the internet that removing the cat on a 2009+ touring bike will help performance.
Do you feel heat from the cat in your car?? How can you feel it when riding your bike, it's behind and beneath you. When you ride the airflow blows all the hot air backwards, right??
Old 01-21-2013, 12:57 PM
Uncle Paul's Avatar
Uncle Paul
Uncle Paul is offline
Airflow does blow much of the heat behind you when cruising, however passengers get some of this hot air on their right foot.
When you slow, have a tailwind, or stop the heat gets pretty down right annoying. Getting rid of the cat gets rid of most of the heat.
GF had a pretty rosie red ankle when city riding on our catted bike. She is much, much happier now.
Without the cats, I am now free'd up to add some Vied's to reduce the lean stock condition, The slightly louder pipes make the bike feel better too.
Old 01-21-2013, 01:14 PM
hardheaded's Avatar
hardheaded
yes until they try it they won't believe. that cat was so hot on my new bike i would leave it parked when it was hot out and ride the evo.
Quick Reply: Decat Pipes
