Want to get max hp on my 120r motor. Need parts advice!!!
Old 01-20-2013, 04:11 PM
ilhan's Avatar
ilhan
ilhan is offline
Default Want to get max hp on my 120r motor. Need parts advice!!!
i am replacing my 110ci cvo sg engine with 120r, i will be trying to get max hp on crank without any turbos or superchargers need some prof advice
thanks.
Old 01-20-2013, 04:27 PM
SE120RG's Avatar
SE120RG
SE120RG is offline
267 cams 12:1 pistons,hurricane heads, 64mm throttle body should get you in the 145 hp range
Old 01-20-2013, 04:41 PM
sporacer's Avatar
sporacer
sporacer is offline
why get a 120r when you can get 129/134 out of a 107.LOL
Im in the process of putting the juice to mine..Tman head work,12 to 1 hd pistons and open up the chambers to get 11.4 to 1. I am also going to use 662-2 cams. TR says a solid 140 square with that setup.
Old 01-20-2013, 04:52 PM
SE120RG's Avatar
SE120RG
SE120RG is offline
Lol. 129/134 out of a 107. And I had people question my 135/132.
That Tman build should be a good one. We have a customer that was going to do that build and decided to go with an Axtell build with tman 662-2 instead. Another possibility.
Old 01-20-2013, 06:07 PM
piesik650's Avatar
piesik650
piesik650 is offline
those are great numbers for a 120r. the dealer where my bike was dyno'ed explained that out of five 120rs they have installed. they are always in the 125/125 range or a bit lower. and one of the motors had some valve train issues right out of the box, and the MoCo was a little bit of a pain to get to "warranty" it but they ended up helping with the issue.
but we are at 5800ft elevation so there isn't alot of oxygen to rip though the motor
Old 01-20-2013, 06:17 PM
SE120RG's Avatar
SE120RG
SE120RG is offline
Yea I agree great numbers for a 120R. We all know every dyno is a little different and some are a little more happy than others. Ours is probably a little on the happy side but no where near as happy as the one that gets 129/134 out of a mild lift cammed 107
Old 01-20-2013, 06:19 PM
sporacer's Avatar
sporacer
sporacer is offline
my stock 120r dynoed 130 hp and 123 tq sae. It did have a 31 tooth sprocket and the pulls were done in 6th gear.
Attached Thumbnails Want to get max hp on my 120r motor. Need parts advice!!!-120r-dyno-001.jpg
Old 01-20-2013, 07:11 PM
stupid_rope's Avatar
stupid_rope
stupid_rope is offline
you gonna sell your 110?
Old 01-20-2013, 07:40 PM
Inspector 12's Avatar
Inspector 12
Inspector 12 is offline
My 120R pulls 139.92 hp and 133.7 tq. The only change out of the box was a set of SE roller rockers.
Old 01-20-2013, 08:14 PM
piesik650's Avatar
piesik650
I would be happy if I bought a 120R and got above 125/125. Once my 124 is broke in I am hoping for 135/135. but I think that's conservative for both motors
Quick Reply: Want to get max hp on my 120r motor. Need parts advice!!!
