Wiring a street glide rear fender lights on a ultra classic
Old 01-25-2013, 11:31 PM
Harleyrider75's Avatar
Harleyrider75
Harleyrider75 is offline
Stage II
Default Wiring a street glide rear fender lights on a ultra classic
I have installed a 2012 street glide rear fender on my 2010 ultra classic but I can't figure how to hook up the light bar and the tri bar light on the fashia. Can anyone give me some instruction please on how to accomplish this? Thanks
Old 01-25-2013, 11:37 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
black is ground
blue is run
red/yel is stop
violet is left turn
brown is rt turn
on your bike.
mike
Old 01-26-2013, 07:03 AM
RPS1981's Avatar
RPS1981
RPS1981 is offline
Don't know if this helps, but a stock Street Glide uses the same wiring harness for the tri-light fender extension that the Ultra uses for the Tour-Pak lights.
So do do both at the same time like I do (added Tour-Pak to Street Glide, the opposite of what you're doing) some splicing will be required.
Old 01-26-2013, 07:29 AM
joe04's Avatar
joe04
joe04 is offline
https://www.hdforums.com/forum/touri...2010-sg-3.html
This is how I wired mine. See my post # 27 for part #s.
Old 01-27-2013, 02:02 AM
Ultra89Rider's Avatar
Ultra89Rider
Ultra89Rider is offline
I have a Detachable Tour Pak on my Road Glide. It has the Rear facis and Tour Pak.
What I did was to make a "Y" harness that split the connection under the side cover. Made it a Plug-N-Play item.
One end plug the Rear Fascia. The other is for the Tour Pak.
I did use Hidden antenna (CB and AM/FM/WB) inside the Fairing.
Old 01-27-2013, 08:55 PM
Camaro's Avatar
Camaro
Camaro is offline
Hey RPS1981: had to do a double take, your Camaro looks exactly like mine - looking good.
Sorry, for the quick high jack of the thread. I'm also interested in putting a tri-bar on a ultra, hopefully we get some good replies!
Old 01-28-2013, 09:17 AM
FXD2003Rider's Avatar
FXD2003Rider
FXD2003Rider is offline
Administrator Emeritus
There's a 3 pin connector at the taillight circuit board:
Pin 1 = tail light
Pin 2 = brake light
Pin 3 = ground
Amp Socket Wiring Housing 3-Position p/n 73153-96BK
Receptacle Contact p/n 73191-96
Attached Thumbnails Wiring a street glide rear fender lights on a ultra classic-taillightcircuitboard_zps50c6fc59.jpg   Wiring a street glide rear fender lights on a ultra classic-8b17a247.jpg
Old 01-28-2013, 07:57 PM
79289Chase's Avatar
79289Chase
79289Chase is offline
If you replaced the whole fender and fascia just go to the dealer and get the stock wiring harness for a 11 or 12 FLHX or FL(not sure of RGC letters). It is like $30. Cut your stock rear harness end off and splice the connector into the new wiring harness or buy the baddad adapter harness.
If you just installed a rear fascia and kept your stock tail light and light bars I don't know how to help you there.
Old 01-29-2013, 08:13 AM
bundy43's Avatar
bundy43
bundy43 is offline
are you using a streetglide fender wo/big tail light,a lot more to it if so
Old 01-29-2013, 08:27 AM
Zooki1's Avatar
Zooki1
Zooki1 is offline
I just seen your post and am i am getting ready to put a 2010 SG fender w/o the big tail light on my 2010 ultra, you say theres alot more to it? Can you tell me what that is? My understanding was there wouldnt be much to it--Thanks, all help is appreciated
Quick Reply: Wiring a street glide rear fender lights on a ultra classic
