Setting of 0.038-0.043 in.
Back to basics. Ohms law:
The resistance of most objects is constant and only varies with temperature. Electric companies increase the voltage to increase the current. Since R is constant and R=V/A, increasing V means A will also have to increase to keep the R constant. If electricity were water flowing through a pipe, the voltage would be the water pressure. The current would be the amount of water the pipe could deliver in a certain amount of time. The resistance would be anything which worked to prevent water flowing through the pipe.
In other words, if Voltage is a constant, the lower resistance is, the higher the current (Amperage) is.
Fine wire electrode spark plugs have a lower resistance. So do most high end plug wires. This increases current.
Now take into consideration, there are a few other things that increase resistance. Static compression ratio, and cam timing come into play. Greater cylinder pressure = greater resistance.
Bottom line is, there is a reason most high end race teams (NASCAR CUP, N.H.R.A. Pro Stock) are NOT using a off the shelf spark plug.
Do a Goggle search and take a look at the $50.00 a piece and up plugs these teams are using.
THERE IS SOMETHING TO IT!
oh dear.
plugs should always be checked before install ( don't forget anti-seize paste on the threads)
gap should be as wide as possible with-out misfire- if misfire occurs, reduce the gap.
the gap spec for a stock plug with stock wires is calculated to allow for the fastest, most complete burn of the mixture- which allows for more time advance, better emissions, power and economy
extra-awesome special plugs and wires MAY NOT complement all stock ignition systems and MAY degrade performance.
Mike
Mike
BrandonNull@yahoo.com
Engine Mechanical Topics
06-11-2011 07:53 PM
