I recently upgraded my front forks so I had to take the ignition selector off. When I reinstalled it I notice that when I turned the key to lock you can still turn the ignition on. I am not sure if I have an alignment issue from taking it off? No I do not have that tool.
So everything seems to be in alignment. It works in all position but when I have the ignition in off position turn it to lock with key it still rotates to ignition and accessorie. What I did notice that it does not seem to be pushing down all the way for the mechanism to catch in the slot? I don't know I have been through the manual several times.
You don't have it aligned properly...seems to be off 1-notch. Remove & get a long screwdriver to turn the slot 1-click to the Left then retry...good luck!
That was my problem too, I used a screw driver and the bottom tumbler was out of wack. I had to "click" mine several times to the left and it dropped right in.
