SERT Map for 2013 Street Glide
Are you sure it is a SERT and not a SEPST. The SERT was black and the SEPST is yellow with a button in the middle of it. The SEPST uses USB cable on the link to the computer and the SERT used serial cable. They also use a different file format. The SERT is .MT6 and SEPST is .dt0 format. I think there is a Street tuner also. Also harley doesn't make the SERT anymore. TTS race tuner I think looks like a SERT. It uses .mt8 files. If it is a SERT you can get it upgraded to TTS tuner.
Put the SEPST on my 2012 FLHX, hope you can find a tuner that will work with it. Biggest problem I found with that over the other tuners is finding a tech that really knew how to get the best out of it, many claimed they did but they didn't. As most of you know the SERT is actually now the TTS Mastertune, Harley should have stayed with that IMHO
Looking for map for 2012 cvo streetglide
I have SERT and looking for best map.I have tried the stage 1 but there's got to be a better one. I have2012 CVO StreetGlide stock 110 with V&H High output slip on's and K&N filter. Also will it still run if I put something else in it some maps say big bore and injecters different heads????? Thanks for any help
I suggest you leave the Smart Tune alone for a while until you get real familiar with how the bike is running. That way when it leans it out in the low speed area below 2000 and in the heavy load area between 2000 and 3000 and you don't have the responsiveness you once had you will recognize it. Shouldn't need to Smarttune. This tune is running on a 13 CVO RG here and doing fine. He does ride very hard.
Let me know if need any changes to it.
