cruise not working
Location: Orig Surfers Paradise Australia, then Riyadh Saudi Arabia, Tokyo, Toronto, now So Cal
1 Post
When both brake switches, brake relay, throttle connector behind A/C, roll off pot/switch, fairing connections are found OK you still have every signal collected from the bike's harness going in and coming out of the ECU. This is a good opportunity to clean all contacts, inspect and protect with grease the big connector located under the seat.
Finally you may simply find an error code
The "Disable" function is activated when the coil of the stop light relay is powered: you need to press "resume" to continue.
The throttle flap position error (measured in volts) will throw a code but may not turn off CC. This must be confirmed by others.
