WardsPartWerks FCS cooling fan install with Howards Hog Horns
Old 03-12-2013, 09:42 PM
Peekayphx's Avatar
Peekayphx
Peekayphx is offline
6th Gear
Default WardsPartWerks FCS cooling fan install with Howards Hog Horns
This weekend I installed a Wards Parts Werks FCS cooling fans on the ol RK. It is combined mounting with a Howards hog horn so I took a few pictures for anyone considering the same install. Quality of the fans is excellent BTW.
pic 1 Howards hog horn (before)
pic 2 remove compressor
pic 3 modify horn mounting bracket by extending notch 1/2 inch deeper
pic 4 remount bracket in new notch
pic 5 mount fan assembly and level
Attached Thumbnails WardsPartWerks FCS cooling fan install with Howards Hog Horns-1_howard_hog_horn.jpg   WardsPartWerks FCS cooling fan install with Howards Hog Horns-2_remove_compressor.jpg   WardsPartWerks FCS cooling fan install with Howards Hog Horns-3_modified_horn_bracket.jpg   WardsPartWerks FCS cooling fan install with Howards Hog Horns-4_move_brack_to_notch.jpg   WardsPartWerks FCS cooling fan install with Howards Hog Horns-5_mount_fan_assy.jpg
Last edited by Peekayphx; 03-13-2013 at 09:05 AM. Reason: added pictures incorrectly
Old 03-12-2013, 09:46 PM
Peekayphx's Avatar
Peekayphx
6th Gear
Old 03-13-2013, 02:44 AM
luisan's Avatar
luisan
luisan is offline
Excellent job,now I would like to see the install of the cooling fans while retaining the ProPad football horn.Thanks
Old 03-13-2013, 10:03 AM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
WARDSPARTSWERKS is offline
Peekayphx, great job on the combined install with Howards horns, many folks are interested in a similar set up.
Lusian, I have a mount solution for the MB horns, the football cover style will visually shroud the fans a bit, but it doesn't have a negative impact on cooling performance.
Old 07-13-2013, 04:11 PM
Windborn's Avatar
Windborn
Windborn is offline
Just installed mine with thermal switch. Static test passed with flying colors.
Old 07-13-2013, 04:36 PM
kwo51's Avatar
kwo51
kwo51 is offline
Do they whistle Dixie
Old 07-13-2013, 04:40 PM
Hex41's Avatar
Hex41
Hex41 is offline
"I want one of these systems". Just got to figure out where to get the money.
Old 07-13-2013, 06:23 PM
kdfcogwheel's Avatar
kdfcogwheel
kdfcogwheel is offline
Just installed mine a couple of days ago. Went on a 755 mile ride through SE Ohio. Rode the OH-555 (Triple Nickel) and my oil temps never exceeded 235*. Works fantastic and great workmanship. My concern here is is there too much weight hanging from the one vibration isolator mount bolt and did you maintain a minimum 1/4" clearance from the cylinders as specified in the installation instructions?
Old 07-13-2013, 06:29 PM
kwo51's Avatar
kwo51
kwo51 is offline
I wish they had a set for our hard hats. I did make sure to have enough distance from motor .
rustybearing
12-28-2009 09:37 AM
m i k e
11-24-2009 08:52 AM
Handycam
06-23-2009 06:44 PM
Grits
03-25-2008 05:11 PM
deadeye
01-18-2008 04:58 PM
Quick Reply: WardsPartWerks FCS cooling fan install with Howards Hog Horns
