Trying to fit a Tour Pak to my Street Glide
I recently purchased a tour pak off of a 2000 Road King. I have a 2009 Street Glide (quite obvious) and mounted it to the detachable two up tour pak mounting rack. The pack sits a little too far back but I cannot adjust it to the front holes because the mounting rack is bottomed out on the tour pak.
Is there a conversion kit/mounting rack to help with this dilemma?
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Sounds like you need a spacer between the pack and mount. Then you can drill tour pack where it will be right for you. Do a search, harley has a spacer that will work for this.
Everything they are saying is true. I had the same issue. Spaced it up with nuts for a while. But I didnt like how it looked, stuck up too far. This winter I had some welding done to the rack to lower the pack and secure it better. Had it powdercoated once finished. I love it now. Check it out here https://www.hdforums.com/forum/touri...olution-6.html. Good luck!
