Need help with custom mapping
I have a 2007 Street Glide and I need help with mapping before I put her back on the road this season.
Over the winter, I put in some Andrews Cams, but I am not sure if the tuning is right.
Here's my specs, any help out there?
2007 FLHX Street Glide
Vance and Hines True Dual Headers
Bassani Slip-ons
K&N high flow air filter
Andrews 48h cams
Power Commander (USB 3)
Bassani Slip-ons
Andrews 48h cams
thanks Def Mute. I looked through them and I don't see anything that matches what I have. Can you recommend anything close? I don't know enough about what would work to have the ***** to try. I'm heading to Laconia this year (about a 1400km run from here) and I want to make sure I have the right tuning.
Well...
Actually, I just looked up the map download page for the OP of the other thread. I'm not going to pretend I know what I'm doing with them! Although I did look through the maps myself, and didn't see a map for your setup. Usually, if the maps don't match up exactly then you pick one that is close to a similar setup and modify it if needed...
You might try contacting Power Commander and requesting a map here:
http://powercommander.com/powercomma...l_support.aspx
sgt_gman2005
12-05-2016 03:14 PM
sgt_gman2005
11-20-2015 02:49 PM
SweeetHemi
Exhaust System Topics
03-23-2013 10:49 AM
