2into1 or true duals
If you're torn between the two it either doesn't matter or you don't have enough information to make what you feel is an informed decision. I think they are both good choices.
Performance gains over stock is noticeable with either option when a common Stage1 is done, but don't expect neck-snapping throttle response - that takes a lot more money.
I would recommend calling FuelMoto and explaining what results you are looking for. They can guide you with good info from a professional stance. I say this from my own experiences with them... good folks!
Since you mentioned Thunderheaders either way, I would stick with Thunderheader. I don't think you will feel much difference between the two unless you are doing more than a Stage 1 download with a high flow air filter. You will get slightly more low end torque with the 2 into 1 over the true duals. Both Thunderheader systems sound awesome. I have the TH 2 into 1 with a Screaming Eagle air cleaner and Stage 1 download and I am very pleased with the performance and the sound. Other riders won't be asking you what exhaust you are running because most all Harley riders recognize the Thunderheader. If you like loud, but not obnoxious, you will love the Thunderheader.
