Which torque value to use: Service manual's or replacement part's instructions?
Which torque value would you choose when replacing a part: Value stated in the service manual or value stated in the replacement part instructions?
In my case, I put on the HD Street Cannon mufflers. Service manual says muffler clamp torque is 38-43 ft-lbs. Street Cannon install instructions say muffler clamp torque is 45-61 ft-lbs. Which to choose? I picked the service manual figuring it's the gospel, but I'm not sure.
Similarly, the bolts that attach the rear of the muffler to the saddlebag bracket. Service manual says 8-12 ft-lbs. Street Cannon install instructions say 19 ft lbs. Which to choose?
Which torque value would you use for the above: Service manual or install instructions?
Anyone know why there's such a large difference between the two sources?
I just put on the mufflers last weekend and haven't had a chance to ride on account of the snow melt and salt roads, so I'd like to get them torqued correctly before I get out on the road.
factory hardware, factory spec.
you can always tighten stuff up, once you collapse a part or stretch a fastener by exceeding limits, you are FUBAR'd
Now if you are using aftermarket parts that would crack if loaded up too much, or using SS hardware that acts like grade 2 stock, etc, it is on a case by case basis
