Voltage Reading
Voltage Reading
I purchased a 2011 Ultra Classic late last summer, so I'm a little unsure whether this is a problem or not. When the engine is running and in Neutral the "Volts" gauge reads around 14, however, when if I'm on the highway the gauge reads around 15. The highway reading seems a little strong. Should I be concerned?
Thanks!
RLJ
Thanks!
RLJ
the voltage regulator should keep the voltage to the battery below 14.7 volts ( no matter what rpm)- higher voltages will damage the battery...and possibly components.
the in dash meter is not accurate, so as suggested above testing with a real voltmeter at the battery will give a 'real reading'
from there you can use the dash voltmeter as a "coarse" measure.
most in dash meters read a little low, and this varies greatly by model and installed accessories.
mike
mike
mike
mike
My 2012 reads 16v rock steady no matter what. A good Fluke DVOM shows 14.8v at the battery. There were some issues with voltage regulators over and under charging the system, so I would recommend testing it regardless of what the HD meter reads.
Received 2,858 Likes
TennesseeEG
04-05-2012 09:34 PM
