Front brake vibration
Old 04-09-2013, 12:43 PM
keith t's Avatar
keith t
keith t is offline
Default Front brake vibration
Had the wheels off to get tires mounted and balanced (Metz 888) and went for a little ride after putting them back on and noticed a little vibration when applying the front brake. Took the pads out and cleaned up the calipers, pads have fair amount left - 2+ mm. Rotors are new thanks to a dumb *** indy that put the wrong bearing in my ABS bike last summer, and I am pretty sure I haven't put any warp heat to them. Planning to check the rotor bolts tonight. Anything else to look for, or might it be "normal"? The rear has no shake at all. I just wish I could say I was positive it wasn't going on before the tire change, but I don't think so
Thanks to all
Old 04-09-2013, 01:01 PM
2black1s's Avatar
2black1s
2black1s is offline
Assuming the vibration wasn't there before the tire change, and the only change you made is the tire, and you now have a vibration in the brakes... Then someone (either you or the person mounting the tire) may have contaminated the rotor with a greasy paw print, or bent the rotor during wheel removal or tire mounting. Try cleaning the rotor and pads with some brake kleen or acetone/lacquer thinner. If they're bent it's not such an easy fix.
Mad Max 454
09-07-2018 11:59 AM
Rain
08-12-2014 08:01 PM
Sean Ferg
03-12-2012 07:08 AM
pirateheadman
11-03-2011 10:26 AM
albngore
01-15-2011 02:59 PM
Quick Reply: Front brake vibration
