Checking runout
I'm replacing my cams with another chain driven cam. Other cam change writeups suggest to check the runout, but why? Am I looking for a number that should concern me? My bike is a 2012 with 5k miles. I'm not sure if I should spend the money to buy a dial to measure this when I'm not sure what I would do with the information I get...and what exactly is it measuring???
That is right about gear drive, as it is gears that will not work with too much runout. Chain drive cams are fine, so you can order them in advance, if you decide to use them.
Ok so if I'm going to change cams to another chain driven cam, does the same tolerance (.003) apply? If not, at what value should I be concerned? Or do I need to check it at all considering my bike is fairly new? Thanks.
If you want chain driven cams I wouldnt bother with checking runout.
But why are you fixated on gear driven cams? I'd bet that the overwhelming majority of cam upgrades are chain.
Some people are very concerned about this spec, with some justification for sure. But improving crank runout requires splitting the cases and doing expensive work upwards of $2K. And then you still have to buy and install your cams.
