rear pulley
Old 04-11-2013, 05:42 PM
hoggy05's Avatar
hoggy05
hoggy05 is offline
Default rear pulley
where can i get a 70t or higher rear pulley for a 2010 limited
also would a longer belt be necessary
trying to tighten up the gear ratio without breaking the bank
thanks for any help
Old 04-11-2013, 05:58 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,537 Likes on 3,054 Posts
How about a front pulley to adjust your ratio instead? (And you can probably still use your stock belt.)
http://www.ebay.com/itm/Andrews-31-T...1433f7&vxp=mtr
Old 04-11-2013, 10:33 PM
mkguitar's Avatar
mkguitar
mkguitar is offline
a front pulley swap may be smarter- longer on labor though.
a rear pulley swap may require removing the belt guard in addition to possible longer belt* AFAIK H-D has not used a larger than 70T pulley.
61,65,68 have been used over the years.
the cush drive may also be a concern.
* a belt swap involves even more labor than a front pulley swap, as the swingarm has to come off in addition to outer primary, primary drive, clutch and inner primary
Mike
Old 04-11-2013, 11:05 PM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
Let us know if you find that 70 tooth with the cush drive. you can put 31 tooth front and do the same thing. Either one will give you a 2.96 final ratio. Stock ratio is 2.875. Makes 2.5 mph difference. A 30 tooth pulley will give you a 3.067 final which is 5 mph difference. It requires a 139 tooth belt. The 31 would work with the 140 tooth.
Old 04-12-2013, 05:38 AM
timberland's Avatar
timberland
timberland is offline
Location: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
I'm headed out the door now, however search for the European Sportster with cush drive. I've read guys here doing a swap...in short its a bolt on. I'll check into this later and post back if no one responds.
Old 04-12-2013, 05:55 AM
Trial dog's Avatar
Trial dog
Trial dog is offline
A lot of folks do the 30/70 swap and I understand use the same belt. I found after a Stage 2 I didn't really think I needed the swap on my tourer. I am getting ready to do this (hopefully this weekend) on my dnya, the hd tri-glide front pulleys are 30 tooth and pretty reasonable for hd, I think about $72 is what I paid.
Old 04-12-2013, 10:17 PM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
The Japanese Sportster Sprocket 40518-08 (68T) will fit the 08 EG bikes. I can't find a number for a 70 tooth with cush drive. If someone has this number please post.
deadhawg
08-20-2023 07:07 PM
JimGnitecki
13
04-03-2014 10:45 AM
GREENOHAWK69
EVO
06-27-2013 10:53 PM
128auto
05-07-2013 11:15 PM
superstandardFL
04-03-2013 02:26 PM
Quick Reply: rear pulley
