Brake Fluid
04-20-2013, 07:29 PM
Brake Fluid
The maintenance schedule for my 2010 flhtk says to change brake fluid every two years.Does anybody change their brake fluid every two years.
04-20-2013, 07:35 PM
I'll likely take heat for this but my 01 had the fluid changed twice I believe. Brakes work fine.
04-20-2013, 07:50 PM
04-20-2013, 07:53 PM
Every five years or so, mostly when I start.
04-20-2013, 07:54 PM
I change mine every two years. Speed bleeders would make this an easy task
04-20-2013, 07:56 PM
Quote:
Originally Posted by
dawg
Me too, with speed bleeders.
04-20-2013, 08:00 PM
I have done it once so far, and it is due to be done again. It does
make a difference and you will be surprised I think on the feel.
04-20-2013, 08:02 PM
Order some spped bleeders and do it every two year as you kinda need your brakes
04-20-2013, 09:54 PM
Brake fluid is hygroscopic - soaks up H2O. I just gave up high performance driving on race tracks where changing the fluid often is a big deal. The H20 boils and you lose the brakes. I don't think it is a HUGE safety thing with bikes, but it is a big deal for maintenance. The water causes corrosion all over the place inside the braking system. I've seen pitting on stainless brake pistons and kind of a sludge in brake lines. In the northwest where the rain is incessant, I change the fluid in both cars, truck and bikes every year. Not a big deal - just do it.
04-20-2013, 09:57 PM
Ahh don't need speed bleeders its easy enough to do with the stock ****....I do it every 10k which is about every year and a half or so.
