RG Fairing NOT fitting on RE-INSTALL
Old 04-28-2013, 09:32 PM
SweeetHemi's Avatar
SweeetHemi
SweeetHemi is offline
Default RG Fairing NOT fitting on RE-INSTALL
DILEMMA OF THE DAY: Trying to reinstall the 2013 Road Glide outer fairing after both inner and outer fairings were removed for DAYMAKER HEADLAMP Assembly, BIKETRONICS 6.5 Speaker and Amp kit and new Apes.. We tried for hours moving wires and repositioning the radio bracket sliding it up and down with the inner fairing and no go! I have heard about fitment problems with RG fairings but this is rediculous! I was spent after the first couple hours and we put the reinstall on hold till tomorrow. Problem is the Top outer and inner fairings where windshield goes will not meet together and and have a 1"+ gap where windshield mounts...and the bottom was a PITA too.
Any tips would be Greatly appreciated!
Old 04-28-2013, 09:53 PM
jus2anoyu's Avatar
jus2anoyu
jus2anoyu is offline
Take a breath have a smoke and a shot of tequila and it will fall right in place....
Old 04-28-2013, 10:00 PM
bigskyroadglide's Avatar
bigskyroadglide
bigskyroadglide is offline
Originally Posted by SweeetHemi
DILEMMA OF THE DAY WAS trying to reinstall the 2013 Road Glide outer fairing after both inner and outer fairings were removed for paint and new Bars.. We tried for hours moving wires and repositioning the radio bracket sliding it up and down with the inner fairing and no go! I have heard about firment problems with rg fairings but this is rediculous! I was spent after the first couple hours and we put the tssk on hold till tomorrow. Top outer and inner fairings where windshield goes will not meet together and bottom was a PITA too.
ok big guy, here is what you need to do, there are two ways to put the fairing back on, one with the headlights and one without, your choice.
putting the fairing back on with the headlights installed is easiest for ME, so you have to get the fairing aligned and make certain the outer edges are spread out. Place the fairing up to the dash and lift the fairing while pushing it forward. The object is to push the mounting bracket into the holes and then let the fairing slightly tilt downward catching the mounting hole upper edges. It may take you one or two tries to capture the mounting brackets but it can be done, do not worry about breaking anything, you really can't unless you are slamming the fairing. I have success with this method within 3 tries every time.
the second method is to take the headlights out of the fairing front and mount the fairing so you can see the hooks catch the mounting holes. Once the fairing is installed, then you need to plug in your headlights and snap them into the fairing. Three mounting holes and make certain the adjustment snap into place.
Either works and should be easily accomplished. Hope this helps
PS, it is alot harder to get the fairing properly re-attached if your headlights are Daymakers. I found this out after installing them, so if you have Daymakers, you also need lots of patience. i have had 7 roadglides of the course of the last 10 years, fairing install difficulty went up by a factor of 3 after Daymaker install. Be patient
Old 04-28-2013, 10:58 PM
SweeetHemi's Avatar
SweeetHemi
BIGSKY:
That's exactly what I installed "The Daymaker" along with The Biketronics 6.5 Speaker and amp kit (mounted on the radio) Everytime I put the Outer fairing into the "Holder" on the radio chassis...It goes on but the top fairings do not come together. Ive re-routed wires and even loosened the radio chassis and slid it up and pulled the inner fairing down and retightened...Still not the answer. Should the Radio chassis and inner fairing both be slide down or up where the mesh together? I know im making this a HUGE sounding project as once I figure it out Ill probably punch myself in the throat!!! (PS: I will edit my question at the beginning of this thread so others will be aware of the Daymaker and Biketronics Kit too.)
I have yet to remove the Daymaker assembly and try reinstalling without it in the outer fairing...that's a good idea. Any other tips you or anyone can chime in??
Thanks ahead of time guys...greatly appreciated!!!
Old 08-04-2013, 02:37 PM
tkbalt's Avatar
tkbalt
tkbalt is offline
Did you ever get this resolved? I just changed my Windshield and found that the top fairings do not come together. I had always left the shield on and had not noticed before.
Old 08-04-2013, 02:50 PM
XARAN's Avatar
XARAN
XARAN is offline
It's probably hung up on the hangers if its all stock. Remove and replace makingbure that its on the hangers. For some its easier to do it with the headlamp out you can see the fairing slide over the hangers.
If this happened after installing the day maker headlamp I've read that there was a bracket problem something about the headlamp adjusters not fitting through the inner fairing holes
Old 08-04-2013, 03:37 PM
texaswiz's Avatar
texaswiz
texaswiz is offline
Leave the headlight bucket out until you get it stabbed in place. Otherwise you are going to have a meltdown and blow someone's brains out.
Old 08-04-2013, 05:31 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Lowcountry Joe is offline
It's much easier without the headlight on my batwing. It's much lighter and allows you to use the headlight hole to see what is causing the fitment issues. It may work the same for you on that shark nosed bastard.
scot210
06-13-2011 11:23 PM
radicalchop
01-28-2011 09:26 PM
creep1
02-21-2010 11:08 AM
Bulldawg
02-24-2007 02:25 PM
Grunt66
10-14-2006 05:14 PM
Quick Reply: RG Fairing NOT fitting on RE-INSTALL
