Brake Light Problems
Old 05-04-2013, 08:41 PM
ceekncabin1's Avatar
ceekncabin1
ceekncabin1 is offline
Stage IV
Default Brake Light Problems
My bike is an 09 Ultra and when I press the rear brake foot pedal, I get brakes but no brake light. When I pull the front brake lever, I get brakes and I also get brake lights. What kind of trouble shooting should I do to find out why I dont have lights when I hit the rear pedal?
Old 05-04-2013, 08:45 PM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Received 20,117 Likes on 10,260 Posts
Replace your rear brake light switch.
Old 05-04-2013, 08:51 PM
ceekncabin1
Stage IV
Thank-You
Old 05-04-2013, 08:53 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
There was a recall on 09 brake switch...did you get yours fixed @ dealer?
Old 05-04-2013, 08:54 PM
btsom's Avatar
btsom
btsom is offline
Pull the wires from the rear brake switch (if you change it, you'll have to pull them anyway) and jumper them together. Use a paper clip or similar wire. Turn on you ignition switch and if the brake light is on, that confirms the switch isn't doing its job but the wiring is OK.
Old 05-04-2013, 09:52 PM
ceekncabin1
Stage IV
Thanks for all the info. I will check with my dealer on the recall for the switch. I have heard of them melting, and I didnt have any issues until we rode out to Sturgis from Michigan in 95 degree temps. When we were coming back from Devils Tower, my brake light stayed on, and cruise would not work. Sounds like that was the begining to the end of the switch. Everything has worked OK until today.
FLYING_BURRITO_BROTHER
09-03-2020 01:03 PM
mikeh1958
06-01-2015 06:21 AM
ECK Road King Classic
Wheels/Tires
11-12-2013 07:51 AM
dagored11
02-04-2010 09:55 PM
BigLowRider
06-24-2009 06:36 PM
Quick Reply: Brake Light Problems
