2008 Eltra Glide Classic oil pressure
Old 05-08-2013, 09:31 AM
Oldboy55's Avatar
Oldboy55
Oldboy55 is offline
6th Gear
Default 2008 Eltra Glide Classic oil pressure
Anyone know what the warmed up idle pressure should be?
Old 05-08-2013, 09:52 AM
mkguitar's Avatar
mkguitar
mkguitar is offline
the o/p is limited to under about 35 psi, by a relief valve in the system.
at idle I usually see 5 to 7 psi when warm- that is with an idle speed of about 1000 rpms- o/p and volume is directly proportionate to rpms.
which is why out bikes seem to idle so high ( compared to classic machines) to keep oiling up as oil is part of the cooling system, removing heat from the hottest parts of the motor
the o/p reading will vary greatly on how warm is warm...or is it hot...
and o/p reading is directly affected by grade/viscosity of oil.
if you see a sudden change- that is reason for investigation-
mike
Old 05-08-2013, 10:06 AM
Sauceman's Avatar
Sauceman
Sauceman is offline
If the needle moves off the peg your GTG
cheers
Old 05-08-2013, 10:33 AM
Oldboy55's Avatar
Oldboy55
Oldboy55 is offline
6th Gear
Thanks guys, That's what I needed to hear, that 5 really shook me up
Bluehighways
2014-2023 Touring Models
20
04-06-2017 07:34 AM
Road Star
Engine Mechanical Topics
15
06-30-2016 09:02 AM
brettnbama
01-10-2013 05:40 AM
FL-kruzen
10-23-2011 10:37 AM
loco2355
01-24-2009 07:59 AM
Quick Reply: 2008 Eltra Glide Classic oil pressure
