Need some help! No running lights....
I've got a 12 CVO Roadglide and the running lights front and rear don't work. I put in some different front LED turn signals, just bulbs, turned on the key no problem they worked fine (run and flash). I then added a rear brake light flashing unit tested it to the setting of flashes I wanted and it worked fine. I went back and checked that everything worked fine. Front turn signals worked fine, white running light and amber flash all good...rear running lights worked fine brake lights flashed as I wanted them to. I then decided to put on the Iron Aces GPS mount. Took apart the spedo/tach assembly unhooked the 3 connections(spedo/tach/info lights) mounted the bracket put it back together and I now have no running lights (tail or front). The turn signals work fine front and rear. The bracket was just mounted the power wire has not been installed yet. Checked the "lights" fuse and it's blown and continues to blow each time it's replaced and the ignition is turned on. It's a visible spark when the fuse blows. I took the new bulbs out and unhooked the flasher unit, still blows the fuse. I even left the turn signal bulbs out completly and left the harness disconnected to the rear fender, still blows the fuse. The bike wasn't ridden between adding these items but it was started at the completion of everything. I'm stomped!!!!!!! Any input would be appreciated.
You have a grounded hot wire. Do you know how to ohm wires out? Using your volt meter put it in ohm setting. Put the positive and negative lead together. The meter should zero out and may make an audible sound. Now ohm your wires out between the different points of problem areas. One lead on one wire, one on the other. Continue this until a connection reads zero, that run of wires is where your problem is.
I can usually smell a short, trust your nose and see if you can smell the area of fault. Good luck.
Take streetglide44's advice - ohm-check the wires & I'd start at the point of failure = speedo/tach assy.
Also, because you're adding after-market & messing w/wiring, warranty repair's not going to be covered so be ready for labor + parts for everything...if you end up taking the bike to dealer.
All I did was unplug the connection to the speedo and the tach, then after finishing with the bracket I plugged them back up....after looking at the plugs they are marked as to what goes where so that you put them back where they came from....I'm baffled because it worked fine then nothing.
